D21 terrano TD27T door ajar warning light relay?
Posted: Sun Oct 25, 2015 8:15 pm
by D21terrano
Hey, does anyone know which relay is for the door ajar warning light? I've had to turn my alarm onto silent as it always thinks the doors are being opened/shut.. I've tried disconnecting the door switches but it didn't fix it so hopefully it'll be an easy fix with a new relay..
Cheers, Tom
Re: D21 terrano TD27T door ajar warning light relay?
Posted: Mon Oct 26, 2015 6:50 am
by Crash bandicoot
might be that unplugging them is the same effect as being open, pull the plug and bridge it with a piece of wire. see what happens
the other option is if it has central locking to wire that particular alarm sensor wire to the lock open out put on the central locking as opposed to the door open as they would still need to unlock the door to get into it, i dont see it being an issue as when you go to lock the vehcile the polarity is reversed so it wont see the signal when arming it.
Posted: Mon Oct 26, 2015 8:13 am
by ChurchurDan
I didnt think they had one. Just door switches to the light, and possibly tyre carrier as well.
