qd32 into d21 terrano
Hey guys ive got a d21 with td27 turbo and manual and also have r50 with qd32 turbo auto. Im looking at doing the swap. Qd into d21. Im looking for advice / knowledge around the gearbox/flywheel part of the conversion.will the td27 gearbox flywheel bolt up to the qd engine?
Nissan Terrano stock standard kind of.
Re: qd32 into d21 terrano
bellhousing fits. qd32eti has 7bolts holding flywheel to crank. use the right zd30 flywheel from memory.
ChurchurDan
And get a D22 navara QD32 gearbox as a QD32eti will tear the small td box to pieces, or use the auto.
Cool thanks for that. Is the d22 box a bolt in or is there some mods involved? Also is the exhaust a bolt up? Ie from the turbo? Just spent abit of time making an good downpipe off the turbo. Hope it bolts up to qd turbo. Fingers crossed.
