Im using a y60 front diff complete with radius arms etc.
Lucky enough i found a sprite diff that has the stronger tie rod ends
I have already gusset the hub balls
And added support to the longside from the diff head to the radius arm mount
Ive heard that the std panhard has the same structual integraty as warm spaggetti.
What about the tie rod?
Budgets well blown so i want to strenghten what i have if i can first.
So ive heard of welding steel angle to the rod.
Do you do full lenght of rod? 75% or 50% lenght of rod and centered etc.
What size angle? and how thick?
Keen to hear your answers.
