2lt white smoke
2lt white smoke
So my 89 surf has a 2lt fitted I have had a starting problem where it starts like its out of fuel then coughs and splutters into life that was the problem for a short time but now has a hudge amout of white smoke on idle and blue under load . Whats some things I can look into my salf before getting it to a garage to be looked at
Re: 2lt white smoke
turbo is leaking oil into the exhaust.
- curly12
Re: 2lt white smoke
Head has cracked.....
Re: 2lt white smoke
if head was cracked it would be overheating or loosing water.
Re: 2lt white smoke
Has no overheating problem at all im going to bite the bullet and send it to the truck shop at work and get them to spend a couple hours checking compression timing head ect before I look for a transplant thanks for the advice
Re: 2lt white smoke
have you checked how much play the turbo has?
