just thought i might check with other saffy owners about how their oil pressure behave ok mine
4.2 non turbo 200,000 kms
when its stone cold it sits about 4, then once it heats up sits on 2 when driven and 0 on idle,
will only reach 4 when stone cold not like a couple of hours later when its cold again
also i did notice the tappets need adjusting, oh and it had an oil change 500km ago max
so what does everyone elses do
safari oil pressure q's
I WISH I WAS A WINCH MASTER BUT I NEED A WINCH TO DO THAT
1991 safari with none of the boxes ticked im a fool!! SOLD
1996 nj paj 2.8td but with the diff lock box ticked
1978 DATSUN 180B sr20 POWERED
Sounds pretty typical of a stuffed oil pressure sender unit
If your worried fit an after market mechanical or electric gauge.
Idle Hot 20psi
100kph in 5th gear hot (2600rpm approx), 65psi
Cold idle around 60psi depending on how cold, how old the oil is, and what brand of oil.
80+ psi at 2600rpm cold.
Idle Hot 20psi
Yep sounds like oil pressure sensor , mine did it about a month after I brought it ,A new one isn't cheap either for what they are I payed $70 for a replacement genuine part .It should sit just on or afraction over 4 at 2100 rpm in top gear and 2.5 ish at idle, well mine does .
Here for a good time not a long time , go hard or stay home.
sender
where did you get ur oil pressure sender unit from at that price?,$180 new from nissan dealers, $85.00 second hand for my safari,my oil light is on and wont go out but the oil pressure gauge works fine,the sender unit does both oil light and the gauge cause theres two wires in the sender unit well thats wots nissan said,any help on this would be good
thanks vince
thanks vince
Sorry guys have no idea where it came from as it was a car dealer that I brought my wagon off who supplied it for me. As for your light staying on thats a head scratcher , once I fitted new sensor the light disappeared and have had no probs since.
- Location: somewhere arround westcoast offroading usually
mine gave up
mine gave up and it still not wrkn if temp goes up then i,ll worry lol
oil sender
oil pressure sender units 12volts or 24volts? for the saf,,,
vince..
vince..
