Terrano Lift
For all Nissan related topics
BMC
Terrano Lift
Post by BMC »
Has anyone used these before to lift terrano?
http://www.trademe.co.nz/motors/car-par ... 480246.htm
Or would I better off purchasing these rear springs and winding up front torsion bar?
http://www.trademe.co.nz/motors/car-par ... 260431.htm
Im after a 2inch lift and would like to fit some 31's if possible.
Thank you
Crash bandicoot
Re: Terrano Lift
Post by Crash bandicoot »
Do the 2wd steering mod before lifting if you haven't already,
jeep cherokee coil springs in the rear, a set of aftermarket UCA's and reindex the torsion rods.
and that's if it's a WD terrano, if its a R50/51 platform poly spacers and dobsons rear springs should do it,
stovanovich
Re: Terrano Lift
Post by stovanovich »
Those are shocks so won't do anything if you don't do springs as well :wink:
What Crash said ^ do steering mods first as once lifted everything turns to custard. You won't need lift if you only plan on running 31s too, so spend the money on better tyres (can do to 33 x 10.5 on standard) & strong steering instead then you just need some JGC V8 or UBS69 Bighorn springs for the rear & reindex torsions to lift it a bit.
Te Rino
"Hubs In, Caps Off"
