Toyota 1KZ-TE cracked/buggered head wanted.
GreyGhost
Post by GreyGhost »
I'm having a look at the cracking head problem on the Toyota 1KZ-TE.
The bottom mounted thermostat doesn't help at all.
I need a 'spare' head to play with to make up and fit an adaptor.
If you are in the Nelson area and have a buggered head that I could 'borrow' for a couple of months then I would be most grateful.
You will get your head back so you can get the scrap value for it.
I just need to use it for a while to make up and fit my adaptor to get the measurements and layout right.
Even a smashed head ('cos you got mad at it?) is fine as long as the front water outlet part is still there.
If it works how I plan it then I'll start making a few.
Thanks for any help.
