plastic sheet
mudsurfv6
plastic sheet
Post by mudsurfv6 »
I'm trying to find some used plastic sheet for putting inside guards between chassis and body to stop mud covering engine. about 1-2mm thick. bendy but will hold its shape.
but can't find any, does anybody know where to get some or what it is originally used for.
I've used some for other vehicles in the past but don't know where it came from and I have none left.
or something else that would do the job but costs stuff all and is easy to find.
thought of inner tube but too soft. one option is corflute, what real estate signs are made of.
any ideas?
Andrew 0272226292.
Big
Re: plastic sheet
Post by Big »
Go to your local roofing outfit as they use plastic sheet in between the iron sheeting etc.. it's about 2 mm thick.. just right 8)
mudsurfv6
Re: plastic sheet
Post by mudsurfv6 »
cool thanks for that, i'll ask around.
Andrew 0272226292.
johnny262
Re: plastic sheet
Post by johnny262 »
Big
Re: plastic sheet
Post by Big »
From the roofers it'll be free :wink: as they just chuck it out.. 8)
Sausager
Re: plastic sheet
Post by Sausager »
What about those blue plastic barrels you can get? I've seen them used a few times.
mudsurfv6
Re: plastic sheet
Post by mudsurfv6 »
Sausager wrote:What about those blue plastic barrels you can get? I've seen them used a few times.
thought about them for the flare part but it needs to be straight and flat for inside bit above chassis.
Andrew 0272226292.
mudsurfv6
Re: plastic sheet
Post by mudsurfv6 »
was in the warehouse today, saw some of those flexible bucket things. flexible but still really rigid, cut the bottom out & handles off, lay rest flat and cut to shape, $7 each so got two and 2 more for flares aswell.
Andrew 0272226292.
Sausager
Re: plastic sheet
Post by Sausager »
Haha nice :D
Return to “Tool Shed”
