GQ Safari Rear Arch Trim
For all Nissan related topics
Dundaberg
Post by Dundaberg »
Gidday all, im guessing this topic may have been covered before. But anyways I have Fitted a set of 35" Silverstones to my truck and looking at it, Im going to get getting some sweet rub when I flex up. Can anyone point me in the right direction of trimming the arches slightly the get better clearance? Even photos of you finished mods would be awesome.
Cheers, Brandon.
tuckertrucker
Re: GQ Safari Rear Arch Trim
Post by tuckertrucker »
Dundaberg wrote:Gidday all, im guessing this topic may have been covered before. But anyways I have Fitted a set of 35" Silverstones to my truck and looking at it, Im going to get getting some sweet rub when I flex up. Can anyone point me in the right direction of trimming the arches slightly the get better clearance? Even photos of you finished mods would be awesome.
Cheers, Brandon.
I'm not sure of trimming them, and I haven't upgraded my tires yet, but I've seen guys removing the factory flares (only held on with screws and a few plastic clips) and the trimming up some plastic sheet that you can get from bunnings or mitre ten and fitting that as flares to protect from stones and mud and shit when it flicks up.
cheers, dylan
Swamped
Post by Swamped »
You could extend your bump stops slightly. Small box shaped to fit stopped 35's hitting the body on my patrol. I also removed the plastics and had already done a rear quarter cut
Dundaberg
Post by Dundaberg »
Cheers for that, might look into the bumpstops. As for the plastic flares, I got rid of those a few years ago.
mudtroll
Post by mudtroll »
Watch out for the seat belt bolt inside the guard, can rip the tyre
Lawson001
Stropper
Post by Lawson001 »
I just fitted 35x11.5x15 Silverstones to my GQ a few weeks ago, on 15x8 -20 rims, definitely chop the seatbelt bolt off flush.
As for the rear guards you only need to chop out the front and rear section of the guard, the top section is fine and the tyre will tuck all the way up with the stock bumpstop with my 2" Bodylift, you may have uptravel probs if you dont have bodylift. front guards are untouched.
I would post a pic if I knew how.
Hope this helps
Twodiffs
Post by Twodiffs »
Pretty much what he said.......Tom (Tomsoffroad) trimmed my rear guards like that and that was for 37's.
charo249
Post by charo249 »
Remove flares do a series of vertical cuts around the guard and beat around with a rubber hammer and reattach flares afterwards.
