Shed clean out
Weemsy
Shed clean out
Post by Weemsy »
Having a shed clear out and have all sorts of stuff to get rid of.
4 brand new, in the box, black spoke 15 X 8 steel rims. To fit hilux, Safari, Pajero etc 6 stud.
-19 offset
Front and rear axles from a GQ Safari or Patrol. 4.11 diffs with LSD rear. Complete, although the front is partially stripped as I swapped the hubs and calipers over.
Bonnet and rear doors from a GQ safari or patrol. Good condition.
Standard springs from a shorty safari GQ.
Leading and trailing arms for GQ
Complete (but in pieces) td42 engine. Good crank and head, picked up slightly on one or two cylinders. Everything else seems in good nick. Inline pump model.
MQ safari complete rear axle with 4.8 diff, brakes etc.
Towbar from a GQ
Will no doubt find more as I go. Offers on everything. Want to clear some space. First come, first served.
Located in Hawkes Bay and pick up preferred.
EDIT - front axle and engine sold.
Also have chrome Bullbar and rear ladders from a GQ and a 12 volt winch, unsure of the make but I think it's a Ramsey
Steve 027 555 22 52
catalystracing
Re: Shed clean out
Post by catalystracing »
PMd you regarding the rims.
Weemsy
Re: Shed clean out
Post by Weemsy »
Engine & front axle sold
Also found a chrome Bullbar and rear ladders from a GQ and a 12 volt winch, complete with cable, leads, solenoid pack etc
Weemsy
Re: Shed clean out
Post by Weemsy »
Please ring or text 0275552252 for quicker reply :oops:
Weemsy
Re: Shed clean out
Post by Weemsy »
Rims sold
12 volt winch, 9000lb not sure of brand? $300??
slidenyo
Re: Shed clean out
Post by slidenyo »
Synthetic or wire on the winch? Do you mean radius arms off front diff as well as rear 4 link ones?
Cheers jase
Weemsy
Re: Shed clean out
Post by Weemsy »
Wire rope
Yep, front radius arms (knackered bushes), rear arms, springs, drive shafts although I'm not sure if these are GQ or MQ
Text me your email and il send pics if you want?
0275552252
Trench_rat
Re: Shed clean out
Post by Trench_rat »
price on mq rear diff? also what is the overall width and the width of the spring mounts? is it spring under or over axle? looking to see if it will fit under my navara
Weemsy
Re: Shed clean out
Post by Weemsy »
MQ axle is 1010mm between spring perch centres
spring under
$250
