best engine transplant for 2.4 petrol
Hey guys I've got a 92 navara 2.4 petrol 4x4 and have blowen up the motor. What's the best replacement engine to put in??
Re: best engine transplant for 2.4 petrol
The best a v8, or most realistic is a Sr20de/t and silvia gear box if ts 2wd or if its 4wd td27-t/qd32-t and matching boxAj19 wrote:Hey guys I've got a 92 navara 2.4 petrol 4x4 and have blowen up the motor. What's the best replacement engine to put in??
- Truck Hore
You could try a petrol 2.4 out of a 92 navara. I believe it would bolt straight in and no need for a cert.Aj19 wrote:Hey guys I've got a 92 navara 2.4 petrol 4x4 and have blowen up the motor. What's the best replacement engine to put in??
- Checkerhead
Lol, that's actually quite a good idea.Gardengnome wrote:You could try a petrol 2.4 out of a 92 navara. I believe it would bolt straight in and no need for a cert.
To be fair, that original question is about as vague as you can get.
What do you value in an engine? What are you going to do with the vehicle? If you give us some context you will get better suggestions.
