unlocking prado diff lock no power
brakes-shocks-lockers-etc
mudsurfv6
Post by mudsurfv6 »
I have the kzj78 prado electric locker in the rear 90 prado diff I'm putting under my 185 surf. is there a way I can unlock it and keep it unlocked without power? and hopefully not pulling it out. will get wired up but will need to be able to drive it before that's done.
Andrew 0272226292.
kbushnz
Re: unlocking prado diff lock no power
Post by kbushnz »
You can cycle it with a battery and some wires...
Normally has limit switches use but you can hook it straight up and listen for the motor to start straining and stop....
Note: It doesn't have power on it all the time when locked or unlocked..... So you can cycle it unlocked and remove the wires.
Hopefully you have gotten it already unklocked so no issues just throwing it in with no wiring.
DIY wiring controller.
mudsurfv6
Post by mudsurfv6 »
thanks for that, will do it sometime.
Andrew 0272226292.
