80 series nitro gear install
Posted: Fri Jan 01, 2016 3:47 pm
hi im doing a Nitro ring and pinion on my front 80s diff open carrier( for now). have just done the pre assemble to check the pinion.
Question the head clearance between the pinion and the carrier is only a hair with all the bearings and pinion tightened, whats the gap meant to be 2mm?
might disassemble and try to move the pinion bearing up. tomorrow
