Toyota low mount winch bit needed
Big
Post by Big »
Howdy peeps, got a second hand winch that needs a bit but that was cracked before I pulled apart to replace seized bearings and upon re assembly it broke off.. :(
and
Does anyone have that bit from a broken / blowen up winch that's sitting in the shed..? I have 1 other contact that may have the bit I need.. any help greatly appreciated.. :D
Happy new year to everyone.. :wink: :mrgreen:
Mattman
Re: Toyota low mount winch bit needed
Post by Mattman »
That's not structural is it? Can you pin it and glue it?
Big
Post by Big »
could get it welded up but would rather a replacement as it's going to get a hard time.. :lol:
Big
Post by Big »
well for the time being it is all sorted.. a mate welded it up for me and I gave it a wee bit of loving to tidy it up, I will try to find a second replacement as Im not 100% sure it's aligned 100% but for the time being.. sweet as :wink:
and this one , it sort of shows the miss alignment I feel :(
more later :wink: :mrgreen:
diogenese
Post by diogenese »
Looks good to me :) fix it when you break it !
mudlva
Post by mudlva »
Mate that looks rough. Could add shims so it bolts up straight but it will need machining to have the motor sit on it evenly.
Imho i would only use it as a spare as those bolts take all the rotational torque loads. Which at a guess is shit loads
Big
Post by Big »
don't have access to a lathe so it's going to have to do until I can get a replacement.. but I hear what ya saying.. the weld is right through so not fussed there.. just it warped just a wee bit on the second side as we had to remove it from where we had bolted it.. it's at a guess 96% give or take a bit right.. may take it off if I can get to a lathe.. :wink:
mudlva
Post by mudlva »
Give me a shout if you have any problems re machining it.
Im no master but got me a turning machine and got plenty of time so i could be of some help.
Will need to courier it up to me thou
Big
Post by Big »
thnx.. I do have a mate just need to get a hold of him.. but it is seating up well and the bolts are only holding it on and twist, and it is socketed into the bracket well so will see how it goes.. but i'll keep that up my sleeve :)
Big
Post by Big »
Oh just for the record.. I got Toyota to price what I need and yes available.. but frame end = 300+ + gst, bush complete set = 300 + + gst and the brush springs what im getting are 10 + + gst all ex Japan.. :lol: so yea.. na.. try source second hand..lol
mudlva
Post by mudlva »
Pm sent
Big
Post by Big »
bewdy :twisted:
