I'm in Wellington now but am moving to Auckland soon so don't mind having to go for a drive to get one
Tim
0273010395
is the plate on firewall still there? whats the axle code? (trans/axle). more likely a 4.5catalystracing wrote:how can I confirm for you.?
Code on plate states A343H G254.mudsurfv6 wrote:is the plate on firewall still there? whats the axle code? (trans/axle). more likely a 4.5catalystracing wrote:how can I confirm for you.?
maybe its had a swap sometime.catalystracing wrote: I thought the A343H was an auto box
if it was manual from factory it is more than likely a R150F, and still most likely is, but if it was originally an auto (going by trans code on firewall plate) and converted to manual then it could possibly be a R151F. different 1st, 2nd gear ratios to the 150.catalystracing wrote:Im told the manual box is most likely a R150?.
