cam work on td42
y60 safari driver
cam work on td42
Post by y60 safari driver »
hi just wondering if anyone has bothered getting cam work done on a td42 and if so what sort of difference it made?
Crash bandicoot
Re: cam work on td42
Post by Crash bandicoot »
Just buy a stump puller cam from kelfords.
mudtroll
Post by mudtroll »
There are a couple in Auckland that have cams done by Henry at Auckland Camshafts Ltd. Not sure the cam alone made a difference, 1 has had head work also, goes very well. Check out https://www.youtube.com/watch?v=3WH4fFb2d8c the truck with the yellow cage.
y60 safari driver
Cheers. I need to get mine tidied up so was tossing up spending a little extra and getting a grind done before the turbo goes on
Craydiver
Post by Craydiver »
I had similar question a few yrs ago prior to Turboing mine
Talked to many people and searched this and the Aust patrol forum
the Overall impression was: if turboed - not a lot of gain for $ spent unless your building a high end engine and after the last 1%.
For NA - great gains,
http://www.patrol4x4.com/forum/engine-d ... wer-66078/
