Will these wheels/tyrs fit my Escudo!?
For all Suzuki related topics
bronx89
Post by bronx89 »
Hey!
Simple question, hoping there's a simple positive answer :)
1991 Suzuki Escudo Nomade (1600cc SOHC 16valve injected 4-door 5-spped manual LWB).
Will 30x9.5" mud tyres on 15x8 -18et wheels fit with NO lift?
89surf
Re: Will these wheels/tyrs fit my Escudo!?
Post by 89surf »
Had to lift mine 2in to get 30s on with 15)7 in rims
zukmeista
Post by zukmeista »
Rims with closer to 0 offset will help with clearance as they move in less of an arc when turning. Should be able to fit 235/75R15 on 15x7 0 offset rims with no lift. 8" rims are too wide for 30x9.5s anyway.
BMC
Post by BMC »
I run 30inch muds on 15x7 0 off set rim.
It's quite tight in there on the rear under articulation with some guard rub.
That's on a OME suspension lift kit.
Need to trim rear guards down a wee bit.
Remember all tyres are not equal and sizes will vary.
I would go with 29's to save hassle.
Tumor
Post by Tumor »
Body lifts are easy to instal.
I would think that a 1 or 2 inch lift would be sufficient.
Life is better off-road
Return to “Suzuki”
