2lte or 5l manual injector pump wanted.
chrome
Post by chrome »
Hi guys.
I'm on the lookout for diesel pumps to convert my 5l into +T
Alternatively I'm looking at the whole deal
Manifolds turbo lines the whole lot
But I NEED to find the pump first. Thanks
DIRTY OLD HILUX
022 519 7700
Smurf
Re: 2lte or 5l manual injector pump wanted.
Post by Smurf »
I have a 2l-te pump here. It is missing the resistors of the side though.
You would be needing a 2L-T one to swap the boost compensator from though? Unless you are working with a 5LE motor?
If you get stuck for one let me know.
chrome
Post by chrome »
Yea I have a 5le motor.
A little confused out of all the options which pump would best suit my needs.
So you have a 2lte. Does that need computer to run? Will that work with the 5le comp??
DIRTY OLD HILUX
022 519 7700
Smurf
Post by Smurf »
Yep I have a 2L-TE. I have looked into turboing a 5LE and same as you I am unsure. I don't think the 5LE ecu has the ability to run boost compensation so probably need to run pump from a 2L-T
chrome
Post by chrome »
I'm being told you need a 5l hiace pump with a 2lt top/compensator
DIRTY OLD HILUX
022 519 7700
tweake
Post by tweake »
i would be inclined to run the 5le pump and tweak the fueling. theres a crude way of adjusting the pump, or chip it.
unless your planning massive fueling it should be fine with the bonus that the timing will be a whole better than what you can do with a mech pump.
