Changes to a certed vehicle
lilpigzuk
Tiger Balm
Post by lilpigzuk »
On behalf of a mate. Vehicle is certed for a few mods from factory, susp etc. he would like to change engine, so do previous certed mods have to be re checked or does certifier only look at the new engine? Will ring local one tomorrow, but thought I would ask and see if anyone knows FOR SURE
bombaybasher
Re: Changes to a certed vehicle
Post by bombaybasher »
My Vk commy was certed for a carby 308 and an M21 box and I switched to an injected motor and a toploader box
The whole car was certed for everything again even the original certed stuff like suspension , wheels,brakes,steering wheel
Madaz
Post by Madaz »
Im pretty sure they recheck everything, unless you managed to get the same certifer to do it again.
Bit of a pain especially if the certifers have different interpretations of the rules and make you change stuff thats already been certed.............
Heath
Post by Heath »
New cert of everything as they replace the cert plate. When I did my hilux I got pinge for the crappy engine install and seats although they had complied to the last certifier.
I had to fix everything to the new guys spec's as his interpretations were different to the old guys.
De-Ranged
Post by De-Ranged »
as stated a full re-check the catch is for stuff that was certed some time back is rules change and the re-check is on the up to date rules.... one especially to watch out for is steering mods
mudsurfv6
Post by mudsurfv6 »
so i guess I had better do the body chop & deck and cage this time round. I was going to cert what I had done when done then do another cert in a couple of years when chop etc was done.
Andrew 0272226292.
Crash bandicoot
Post by Crash bandicoot »
mudsurfv6 wrote:so i guess I had better do the body chop & deck and cage this time round. I was going to cert what I had done when done then do another cert in a couple of years when chop etc was done.
Do it all, as the new certifier has the right to reverse a previous certifiers judgement on a modification. meaning anything done on the 1st cert plate maybe not up to par with the new certifier
just assume nothing is certed and go from there. safest bet.
mudsurfv6
Post by mudsurfv6 »
yeah just means it will be off the road for longer. be better bet in the long run I know. gotta save up more $, and find someone to glue the body back together after I have cut it to bits.
Andrew 0272226292.
Crash bandicoot
mudsurfv6 wrote:yeah just means it will be off the road for longer. be better bet in the long run I know. gotta save up more $, and find someone to glue the body back together after I have cut it to bits.
Plenty of guys around that can do that.
mudsurfv6
Post by mudsurfv6 »
will have to put out an sos when I'm ready, might be a while the rate its going.
Andrew 0272226292.
