get the biggest cooler you can fit for trans, they are very strong but need the cooler(same trans in earlier VX's (A440 hydraulic trans-A442 electronic i think)and common problem I think) you could drop the trans pants and check the filter otherwise big ass cooler, before you tweak.. EGT is a must otherwise you play with fire..
then follow the tweaks on net.. there are loads.. but don't over do it which is where egt come into it.. as they will climb very quikly.. Great trucks and good luck
