Lower ratio diffs fro vitara?
I have just bought 2.4 transfer gears for my vitara the guy i got it off also had 2.7-2.8 diffs but kept them Is there any where i can get some?
If you don't succeed. Try again with "more revs".
https://youtu.be/d9o8YZLmOPs?t=1m34s
Re: Lower ratio diffs fro vitara?
The lowest geared factory ratio is 5.12:1. The only lower geared ratio I know of is these ones, not sure how good they are haven't seen any reports on them. http://4xfourart.com/Products/19/Vitara.aspx
Where did you get the 2.4 transfer gears from?
A guy i know done alot of work to his vitara including getting made up 2.4 gears he got them made through howart engineering
Interesting, I'll have to give them a call. Thanks.
I can say they are not cheap to get built you will be looking at around $1200-1500
