Tyre sizes
Tyre sizes
I've just bought my first truck (1990 turbo diesel Terrano) and i'm currently saving up for new tyres but i'm not sure what size to get. It came on 30/9.5/15's but 31's seem like an easy way to get a little more height However i'm not sure if they'd fit without offset rims or if they would even be worth it. So any advice would be quite helpful.
Re: Tyre sizes
What kind of tyre are you looking at? 31x10.5 all terrains will go straight on, 31x10.5 should fit standard, just you'll likely need to adjust steering stops to stop them rubbing on full lock
Re: Tyre sizes
keep the standard offset. 31s will fit clear, unless the suspension has sagged LOTS.
You will notice slightly worse fuel consumption with the taller tyres.
Re: Tyre sizes
if you keep the standard offset, you can fit 33x 10.5s x15s with 2"body 2"susp. lift. Thats 10.5 wide not 12.5
Re: Tyre sizes
Cheers for all the advice, I'm looking at getting a set of muddies I think. So since 31's will fit It'll come down to price difference i suppose.
