WTD: Range Rover Rostyle steel rims
Wired1
Stropper
Post by Wired1 »
These look good on a 110 so I'm after a set of five or any other quantity I can get. Close to Nelson/South Island would be nice.
lilpigzuk
Tiger Balm
Re: WTD: Range Rover Rostyle steel rims
Post by lilpigzuk »
Pending on what you believe on the net, they weren't weight rated for the 110's, only the 90s and classic rangies.
De-Ranged
Post by De-Ranged »
Does this mean they aren't "a suitable rim for the use intended" under LVVTA..... was looking at cutting the centers out and fitting them to a set of 15x10" rim hoops, I also like that old school look but want to run a wider tyre and with cert manufactures recommendations are law so need a 9" wide rim or wider to run a 12" wide tyre
Cameron
Post by Cameron »
as long as you don't load it past the factory load ratings of a range rover I can't see any problem?
muddy
Post by muddy »
De-Ranged wrote:Does this mean they aren't "a suitable rim for the use intended" under LVVTA..... was looking at cutting the centers out and fitting them to a set of 15x10" rim hoops, I also like that old school look but want to run a wider tyre and with cert manufactures recommendations are law so need a 9" wide rim or wider to run a 12" wide tyre
I had a set of these which I flipped the centres on to increase offset. The centres are rolled so a flat surface sits against the inside of the rim and it's then riveted or spot welded. If you reduced the diameter you would have to cut off the flat part significantly reducing the strength. I guess a continuous weld would still work though... On the plus side - they are not lightweight rims - there is plenty of steel in them.
Wired1
Stropper
Post by Wired1 »
Still looking, I've seen them on a 110 and they are a nice fit if you like the retro look. I'll buy singles or pairs or any odd quantity...
BadCo
Post by BadCo »
I have a spare one in Auckland if you are that keen...
De-Ranged
Post by De-Ranged »
Wired if it helps i could pick it up and bring it to Napier, catch is i've just had surgery and wont be back at work for about 5 weeks
If its to much hassle i'd be keen to grab it as i need 1 more for my set
Cheers Reece
UBZ
Post by UBZ »
Are you still looking for a set of these rims ? I have a set for sale and will be passing through top of south Is in a few weeks time .
