longer shocks for 96 surf
brakes-shocks-lockers-etc
Mattshilux
Post by Mattshilux »
in the process of lifting my surf and i need some longer shocks. Good condition 2nd hand would be ideal for front and rear.
ta
MihiT
Re: longer shocks for 96 surf
Post by MihiT »
How much lift?
Not that I have any, just might help someone who does.
1989 LWB 5-Seat TD42
Mattshilux
2 inches
floatingkiwi
Post by floatingkiwi »
Gnerally all the aftermarket stuff is the same size shocks and just heavier springs. I've found ironman and Dobinsons are about the only ones that have rear springs that are captive. My Gabriel shocks are slightly longer in the back than stock. (to suit 4runner).
I still use EFS up front.
If you get longer shocks up front you may damage CV's.
1999 KZN185W SSRG TJM T-15 Bar, Tigerz11 2speed winch, 2" EFS sus lift, 265-75R16 Engine guardian. Auberins EGT. LED light strips. weathertech cargo liner. Safari Snorkle SS145HF. Prado rad. Front and rear E-locker.
Mattshilux
I have had a few conversations with people about putting landcruiser shocks in the rear. The aim of this truck is to make up for the ifs front end by a very flexy rear end with a lokka. What are peoples thoughts?
mudsurfv6
Post by mudsurfv6 »
standard height 80 series shocks give a surf 2" lift, 2" lifted 80 series shocks give surf 4" lift.
I've had standard 80s on a surf and I've put 80 2" lift on back of my surf that's not back on the road yet. will see how they go.
auto unlockers are a good budget option, lokka unlock easier apparently so will see how mine goes in the front. I've used lockright and they seem a bit tight.
Andrew 0272226292.
Smurf
Post by Smurf »
Shocks don't give a vehicle lift, Springs do. :-)
mudsurfv6
Post by mudsurfv6 »
Smurf wrote:Shocks don't give a vehicle lift, Springs do.
yes you are right. but you know what I mean. :)
mudsurfv6 wrote:standard height 80 series shocks ALLOW a surf 2" lift IF THE SPRINGS ARE LIFTED 2", 2" lifted 80 series shocks ALLOW surf 4" lift IF THE SPRINGS ARE LIFTED 4"
better? :)
Andrew 0272226292.
