hi all
My 80 is leaking. The door seals must be stuffed. After it rains wet sills all round and smelly carpet.
Has anyone had this problem and replaced. Where could new seals be found?
80 series
- skid
- Tyre Man
Re: 80 series
Does it have a sunroof ??
Buy good thick weedeater wire and feed it down the drain at the front corners of the sunroof to clean them out. Water should be dripping out the bottom of the vehicle way down below the bottom of the A pillars somewhere
- Bush Crasher
Re: 80 series
hi
Yea ,skid its definitely not the sunroof now. I couldn't find any wire in the shed so.... silicon sealed up until i make a steel panel for it, I hate that sun roof.
So while up there checking after heavy rain, sunroofs good but door sills still wet, i noticed the roof drainage channel up the windscreen are closed over. (likely branches squashed them over time) Can anyone tell me what kind of gap it should have???
