http://www.youtube.com/watch?v=muS3qMg5n1c&mode=related&search=
any ideas wise ones how the hell this works
mudchuka wrote:yep works well, even crc will do it.
thats the problem with 10 inch rims, stick with 8's
Mark wrote:any ideas wise ones how the hell this works
See he sprayed quite a bit of the spray/fluid into the tyre first. Then when he sprayed the flame at it the gas inside the tyre would have lit causing a mini explosion inside the tyre, pushing it out onto the bead. I guess there would be no risk of fire inside the tyre because all the air would be used up in the initial explosion, starving the flame of oxygen once the tyre seals on the rim.
An explosion is a sudden increase in volume and release of energy in a violent manner, usually with the generation of high temperatures and the release of gases.
