Whats the "correct" way to check auto trans fluid in an old 95 Mistral auto? Have drained and refilled mine twice but would like to know it has enough...or if I've overfilled it.....
Hot then idle in park, or neutral..or cold?
Thanks guys
Correct way to check trans fluid
Re: Correct way to check trans fluid
What did you bother draining it for ? How much actually came out ? My guess is about 4 litres of the 12 or so in it
Idling in neutral is my belief
From FSM
Thanks for that info, is it idling in neutral or shut off and checked immediately? Thanks
