What battery cca for TD27T please?
Posted: Mon Jun 06, 2016 6:56 pm
by altair
Battery in my Mistral is buggered, what is the minimun CCA requirement for these TD27 engines? Seems 600 to 630cca is the common size in an NS70 battery, but I have a 750 CCA in there now, which is putting out 600 when checked..will start it once, but not twice until its had a run. Heaps of NS70 batteries around at 630CCA, this good enough? What size do you guys run for a daily driver TD27? Just the single battery, Cheers
Re: What battery cca for TD27T please?
Posted: Mon Jun 06, 2016 7:15 pm
by stovanovich
go the N70 instead instead of NS70. 730cca gives you more option for accesories then
Posted: Tue Jun 07, 2016 8:28 pm
by Crash bandicoot
lead acid 660cca or higher. not deep cycle and not sealed.
