Winch for my hilux
simintrev
Winch for my hilux
Post by simintrev »
Hey guys after having to chainblock off a tree for 4 hours i decided it was about time i got a winch.
I have a ln106 hilux pretty standard at this stage and was wondering what you guys recommend.
Was looking at this runva winch and this mudstuck one.
http://www.winch.co.nz/categories/runva ... ch-dyneema
http://www.trademe.co.nz/motors/car-par ... 489466.htm
mudlva
Re: Winch for my hilux
Post by mudlva »
neither of those options
he runva is a rock crawling winch with only 14m of rope
the green unit is way slow for what it is
personnally throw another hundy at it for one of these units
http://www.winch.co.nz/categories/runva ... 2v-dyneema
26m of rope and fast on easy recoveries with plenty of power
on harder recoveries double purchase using a pully block and line speed will still be better than the green unit but with twice the strength
value for dollar its up there imo
Smurf
Post by Smurf »
I'd second Mudlva's comments.
I have the Runva he has linked and it is a good unit. Actually I have the next model up, but essentially the same winch.
Just pull it apart and check all the seals are present and correctly fitted between the motor and drum and gearbox. Mine weren't and water killed my motor in 6 months. It was repaired under warranty though. :-)
simintrev
Post by simintrev »
Oh true awesome has a lot more grunt ae. You guys get away with a high cca single battery?
00falcon
Post by 00falcon »
simintrev wrote:Oh true awesome has a lot more grunt ae. You guys get away with a high cca single battery?
I have the EWX9500-Q on my Wrangler.
I cant rate it highly enough...!!!
It has pulled me and others out of some hairy situations... (granted my Wrangler is probably lighter than yours...(1800kgs))
I ran it without issue for a couple of years on a 650CCA battery, altho i now have an Optima.
Added to the cost of the winch were lengths of cable to keep everything else happy and dry hidden away in the engine bay...
O[][][][][][][]O
Eat, Sleep, Jeep...
www.nzjeepclub.co.nz
Smurf
Post by Smurf »
I am running a blue Exide orbital in my 4WD
simintrev
Post by simintrev »
Awesome cheers guys! Ive got a good battery at the moment but do remember some fancy one at the shop that seemed better suited will look into it.
4wdstuff
Post by 4wdstuff »
Good option for winch battery is the yellow top http://www.4wdstuff.co.nz/catalog/batteries-optima
Can also agree that the EWX9500-Q (9,500lb) is good or even the EVO version which is a little bit faster, but also as said above the waterproofing is not as good as they suggest, if it is being submerged good idea to strip, clean out and regrease.
Tim
muddy
Post by muddy »
Another tick for the RUNVA 9500-Q. Running on a Clubman truck (Disco) in Mainland Winch Challenge series. Two rounds done with no winch problems and pretty impressed at the price. Running 2 x 600cca batteries
simintrev
Post by simintrev »
Awesome cheers for help guys! Pretty sold on the runva EWX9500-Q will be in the shopping cart very shortly. Next step is building a winch bar hah
