Vitara Engine Problems
For all Suzuki related topics
Nato
Post by Nato »
Hi guys my 89 Vitara 8 valve is vibrating heaps at idle and when I turn it off it hesitates then slowly shudders to a stop (alot slower than normal). Anybody have any idea what this could be??
mroffroader
Re: Vitara Engine Problems
Post by mroffroader »
Nato wrote:Hi guys my 89 Vitara 8 valve is vibrating heaps at idle and when I turn it off it hesitates then slowly shudders to a stop (alot slower than normal). Anybody have any idea what this could be??
water in you dizzy?
Nato
Post by Nato »
no I checked that today seems fine, i did get a new 2 inch exhaust on Friday though so maybe been running too rich and fouled up the plugs? Might explain the running after turned off if carbon on plugs still glowing. Guess it might explain rough idle at times as well as it drives fine all the other time. It makes a quiet popping sound when gas pedal is released.
mud_slinger
Post by mud_slinger »
check plugs sounds like caroned plugs, you might have to adjust ya mixture possibly could be too rich and check your timing
needs more curry
0272593533
mroffroader
Nato wrote:i did get a new 2 inch exhaust.
you got some more info on this? you may not have enough back flow/pressure :?: how many mufflers you got on it etc maybe some pics?
Nato
Post by Nato »
All fixed! turned out it was just a vacuum hose from the carb that had fallen off(a little one very hard to see). As for the exhaust, its pretty free flowing only one high flow muffler on it. Cheers
mroffroader
Nato wrote:All fixed! turned out it was just a vacuum hose from the carb that had fallen off(a little one very hard to see). As for the exhaust, its pretty free flowing only one high flow muffler on it. Cheers
good to hear its fixed.....my vitara has just developed a major gearbox/clutch problem :oops:
spanky
Post by spanky »
whats your problem mr o is it clutch or gearbox?
mroffroader
two people think it *may* be a seized release bearing? :cry:
warlord225
Post by warlord225 »
so really it could be anything then. good thing suzuki gear boxes are light.
mroffroader
warlord225 wrote:so really it could be anything then. good thing suzuki gear boxes are light.
and cheap :oops: ............yes it could be anything but thats what happens when your silly and thrash your suzuki.......and lovin every minute of ithahaha :twisted:
Return to “Suzuki”
