94 XJ WOF woes
slo_mo
94 XJ WOF woes
Post by slo_mo »
Hi Guys,
Just got some news on the XJ failing a WOF on the below.
Panhard rod ball joint naffed
Exhaust manifold leaking - apparently just the gasket
Needs new front rotors and pads
Steering box mount cracked - does this need certing to be welded up?
Crash bandicoot
Re: 94 XJ WOF woes
Post by Crash bandicoot »
Steering box mount crack repairs are classed as a repair not a modification. No cert required.
Panhard rod bushes or ball joint????
Or do you mean draglink ball joint
lax2wlg
Re: 94 XJ WOF woes
Post by lax2wlg »
Its a Jeep so the panhard has a balljoint
slo_mo
Re: 94 XJ WOF woes
Post by slo_mo »
Crash bandicoot wrote:Steering box mount crack repairs are classed as a repair not a modification. No cert required.
Ah some good news, would reinforcing it be classed as a modification? I don't want to get it reinforced then find I need to cert for just that. Rather cert later once the rest of the Jeep has been sorted out.
Also looking at the do it once do it right option to mitigate as it is my daily driver.
Panhard rod apparently the ball joint
Any good welders in Auckland on here?
Return to “Jeep”
