what removes battery acid stains
basics
Post by basics »
what removes battery acid stains from concrete? ie my drive way :x
is their anything i can use that i will find around the house?
or whats a good brand that works and you would recommend? cheaper the beter :lol:
99 pajero exceed 3.2
mudlva
Re: what removes battery acid stains
Post by mudlva »
Unsure about battery acid butbit would be worth trying a product call crl for calcium rust and lime.
Another idea would be milk as its alkaline verse acid but no experience as such
basics
Post by basics »
mudlva wrote:Unsure about battery acid butbit would be worth trying a product call crl for calcium rust and lime.
milk would be a cheap option? sounds too good to be true, any one had any experience
Big
Post by Big »
we use sulfuric acid to clean concrete.. diluted accordingly depending on how dirty etc.. it'll lift just about anything but very caustic.. worth a try.. placemakers will have it
basics
Post by basics »
Big wrote:we use sulfuric acid to clean concrete.. diluted accordingly depending on how dirty etc.. it'll lift just about anything but very caustic.. worth a try.. placemakers will have it
cheers, il have a look and see next time im in town,thanks for the reply
TJ
Post by TJ »
Acid in the battery would be sulphuric acid to start. If that is what left stains on the concrete, how are you expecting it to remove the stains by sulphuric acid?
Big
Post by Big »
TJ wrote:Acid in the battery would be sulphuric acid to start. If that is what left stains on the concrete, how are you expecting it to remove the stains by sulphuric acid?
well i think its sulphuric acid.. Its sold to clean concrete and lifts amazing shit off I got a bottle in the garage so will look tomorrow i think but i also think its a lot stronger too..it really depends on the concentration level you need. it is very caustic and does work if used properly
sirLachlan
Post by sirLachlan »
Hydrochloric sounds more likely ...
Gardengnome
Truck Hore
Post by Gardengnome »
From what Big has mentioned with an acid based product for cleaning concrete I'm thinking your stain is more than likely the opposite. A clean spot on a dirty driveway.
If so your options would be dirty up the spot or clean the rest of the drive.
TJ
Post by TJ »
Gardengnome wrote:From what Big has mentioned with an acid based product for cleaning concrete I'm thinking your stain is more than likely the opposite. A clean spot on a dirty driveway.
I think this as well.
basics
Post by basics »
they were really redish orange marks,and very obvious.
water blasted and scrubbed with degresser and thats half cleaned up the stains, but still there. depends how fussy the agent is on the next flat inspection wether or not i have to go buy something.
water blasted the whole drive way while at it which makes them stand out even more :roll: :lol:
TJ
Post by TJ »
Reddish orange marks are probably from the rust and corrosion of the metal battery tray. Battery acid by itself would not cause that. When the acid leaked, it took metal with it.
Can you not just park something on top of it on the day of inspection?
De-Ranged
Post by De-Ranged »
Hmmm I'd suggest some light grey spray paint.....
mudlva
Post by mudlva »
Mix up a paste of cement powder and water and scrub it into the stain.
This should help remove the acid and recolour the stain at the same time.
Leave a small layer on top of the area, it will turn white but over time it will fade.
Will be better than red :lol:
mudlva
Post by mudlva »
Haha just seen the clr add on tele.
Scrub it onto the rust area and rinse off
Return to “Tool Shed”
