So today I failed WOF on a few things, one of which was "tread beyond guards" - worse there's actually an imbalance left-right: the tyres are a good 5/8ths further out on the driver's side.
So i need to add some flares,I may end up getting the front guards rolled but the rear is a custom tray, so it will be strips cut off the 44gal and tec screws to get the wof, then off again!
Also needing to deal with (presumably) the body mounts to get it centered, and since I'm going 33s soon, I may as well add a bit of lift, plus undoubtedly the OEM mounts have crushed down.
There's a material I hear of as "self lubricating nylon" - is this the good stuff? (and what is it properly called, and dous anyone in a workshop have a bar in the scrap bin for me) would it not be too rigid and give a stupid-harsh ride?
The point of this thread:
body mount materials?
bright ideas on flares, either quick detachable, or permanent and styley?
Body lift Safari and flares
1989 LWB 5-Seat TD42
Re: Body lift Safari and flares
OR do I do the hoary and put coil spacers all round?
MihiT wrote: tec screws to get the wof, then off again!
just remember for insurance vehicle needs to be in a wofable standard, doesn't seem like much, but you don't want to give them a chance to say 'NO'.MihiT wrote: flares quick detachable,
same with people putting small wheels on for wof then putting big wheels back on after wof. claim void sorry, its happened before
I got some rubber/bendy plastic round buckets from the warehouse. (like horse feed buckets) cut to fit. solid enough to hold shape but bendy enough to bend if you rub against something. cost stuff all too. not on my truck yet but should still look ok when are.MihiT wrote:bright ideas on flares permanent and styley?
Andrew 0272226292.
Andrew 0272226292.
I made up some flares for my truck the other day, got a reel of 75mm black garden edging from Bunnings. Drilled and pop riveted into the underside of the guards and it passed a wof no problem. Total cost was around $30 with rivets. Looks ok and is pretty solid. Cuts easily with a panel saw or hacksaw. Not as flexible as i'd like but to be honest it doesn't really spend any time brushing up against banks or trees.
Wheels further out one side than the other will be due to panhard rods with lifted springs - you need to get adjustable panhard rods. It's not a body mount problem
I did wonder that, but the springs I put in should have been standard height. I did ponder just upgrading to HD and adjustable pannies. This thing's keeping me damn poor!muddy wrote:Wheels further out one side than the other will be due to panhard rods with lifted springs - you need to get adjustable panhard rods. It's not a body mount problem
The buckets I'm picturing are pink and rubbery, I suppose it depends on your definition of "styley" :pmudsurfv6 wrote:MihiT wrote: tec screws to get the wof, then off again!just remember for insurance vehicle needs to be in a wofable standard, doesn't seem like much, but you don't want to give them a chance to say 'NO'.MihiT wrote: flares quick detachable,![]()
same with people putting small wheels on for wof then putting big wheels back on after wof. claim void sorry, its happened before![]()
I'm not sure about garden edging, but that has bought to mind DPC, though whether that's rigid enough to satisfy Mr Nitpick.Pj_Marsh wrote:I made up some flares for my truck the other day, got a reel of 75mm black garden edging from Bunnings. Drilled and pop riveted into the underside of the guards and it passed a wof no problem. Total cost was around $30 with rivets. Looks ok and is pretty solid. Cuts easily with a panel saw or hacksaw. Not as flexible as i'd like but to be honest it doesn't really spend any time brushing up against banks or trees.
I wonder if ag-bars count or whether it has to be a mud guard arrangement
I got black ones, and rigid rubber.MihiT wrote:The buckets I'm picturing are pink and rubbery, I suppose it depends on your definition of "styley" :p
if your meaning bar work above wheel between front bar & running board/sliders, then I have had that on vehicles and as long as covers tyre looking down and is reasonably close to guard has always passed a cert/wof.MihiT wrote: wonder if ag-bars count or whether it has to be a mud guard arrangement
Andrew 0272226292.
Andrew 0272226292.
Chocolate fish for this guy!Pj_Marsh wrote:I made up some flares for my truck the other day, got a reel of 75mm black garden edging from Bunnings. Drilled and pop riveted into the underside of the guards and it passed a wof no problem. Total cost was around $30 with rivets. Looks ok and is pretty solid. Cuts easily with a panel saw or hacksaw. Not as flexible as i'd like but to be honest it doesn't really spend any time brushing up against banks or trees.
Just bought myself a roll and fitted +35mm gourds all around. I had to drill the frame of the tray but used the existing quarter-liner screws and fixings for the front. I will post pictures sometime.
Got the 2000w hair dryer on it and the edging forms to shape quite well, I've also learned that my LH panel is f*cked! bent well out of shape.
Ag bars coming up!
