Hey Guys
I'm scheming here but I don't have a landy to measure, would anyone be kind enough to measure there 88 SII or III for me?
The measurements I need are:
1. Rear body length, back of front door to rear of tub.
2. Width of the lower body above and below the rolled side.
3. Length of the front guards.
4. Overal length of body, front of front guard to rear or tub.
5. Horizontal distance between centerline of rear axle and rear of body.
6. Horizontal distance between centerline of front axle and rear of front guard.
7. Width of the top of the windscreen.
Also does anyone know how deep a series one door is?
It'd be awesome if someone could help me out with some or all of the dimensions as I have no way of finding one to measure right now.
Cheers guys.
Landy dimensions.
- Disconewhere
- Bush Crasher
- Disconewhere
- Bush Crasher
Re: Landy dimensions.
Disconewhere wrote:Also does anyone know how deep a series one door is?
Series 1 doors are 840mm wide x 480mm high
- Disconewhere
- Bush Crasher
- Disconewhere
- Bush Crasher
Hey Turoa, cheers for that, gives me some good dimensions to work from to put into CAD and see how things might look. Would you mind measuring two more things for me?
1.The height from bottom of the door top to the top of the door top.
2.Length of top and bottom side of the door top?
3.The width of the body where the hardtop mounts, this is #2 from my initial post.
Cheers for your help, I owe ya a beer sometime.
