Biggest tire I can put on 15x7 ?
sirLachlan
Post by sirLachlan »
Ln106 plus 50 mm springs . Truck has cert for the 5l plus turbo and seats .
Cert tag says 15x7 coz it had those alloys and roadtires on it
Wayne martin failed it for a wof with 15x8 -20 steelies with 31x10.5s on it .
I thought it looked petfect really but I wont argue
Anyway I still have the alloys so just swap for a wof .
Im considering buying some 32 or 33s on what ever rims suit ( and flares?) and just putting alloys on for wofs
Or can I technically put for ecample 32x11.5 on the 15x7 and still get a wof ?
Thanks
sirLachlan
Re: Biggest tire I can put on 15x7 ?
Lvvt fact sheet says biggest for 7 inch rim is 31x10.5s . Or 265 75 15 . So theres no middle ground as far as a compromise I was going to consider .
2 sets of wheels it is
MihiT
Post by MihiT »
What was the actual WOF failure?
I was failed on "tread outside guards" with x10.5s on 8" rims.
Currently running 33x10.5 on 7" rims, -19, with flares.
Goodrich's 32x11.5s minimum recommended is 8"w, but the 33x10.5 suits 7" So you'll have to look at the manufacturers specs to find something suitable.
1989 LWB 5-Seat TD42
sirLachlan
He wrote both . Guard /tire coverage and then 8 inch rims lvv plate on the line below .
Yea ill look into it properly in the future .
Have you just got the 50mm flexi flares ?
MihiT
Post by MihiT »
sirLachlan wrote:He wrote both . Guard /tire coverage and then 8 inch rims lvv plate on the line below .
I'd find another WOF guy!
I just DIYd some, on advice from members here. I think they're about 30mm outside stock guards.
