D22 Navara 2WD Ute. replace n/a TD27. What TD27T do I need.
Posted: Thu Oct 06, 2016 10:42 pm
by Willy
Hello peoples,
I'm looking to put a mechanical pump on a TD27ETI for my 2000 D22 2WD ute.
There seem to be the R50 (Front Mount) and 1997+ R20 (Top Mount Mistral II) versions around.
Questions.
1. Will the TD27ETI with the top mount IC allow the bonnet to close on my D22?
2. Will any TD27T pump with compensator allow this setup be dialed? Looking at 15 psi with 2.5" exhaust and egt to keep an eye on things.
I'm hoping the blocks are identical and that my alternator/power steering, a/c can just be bolted on and that the manual flywheel will mate the crank.
Additionally I may have to change the sump / pickup over as most are out of 4wd's and look heaps deeper, and LVV to keep the paper work up to scratch.
Have I missed anything?
