jumpy tach
For all Isuzu related topics
fish
jumpy tach
Post by fish »
Hey fellas has anyone experienced a jumpy tachometer needle?
Its in my rodeo wich is an isuzu really, it goes up when i turn to the left and down when i turn right, so its affected by gravity somehow and most of the time sits about 2.5 regardless of actual rpm, its annoying me!
Pj_Marsh
Re: jumpy tach
Post by Pj_Marsh »
Sounds like the cable is loose
fish
Re: jumpy tach
Post by fish »
i had a poke around but couldnt figure out where the sensor is,
sirLachlan
Re: jumpy tach
Post by sirLachlan »
Want to swap ? mine is 500 rpm for engine tuning aND 1500 when I toot the horn . Ha ha
Electronic in a ln106 tho
MihiT
Re: jumpy tach
Post by MihiT »
Unless there's a known solution for the vehicle, my general advice would be to pull the cluster and re-solder all the connections on the daughterboard. Check for wires around the steering column that are pulling, pinching or rubbing.
1989 LWB 5-Seat TD42
Re: jumpy tach
my 80 series used to do that as well, then one day it just stopped working
speedo cable had snapped
sirLachlan
Re: jumpy tach
The tacho was jumpy coz the speedo cable snapped ??
nzlux
Re: jumpy tach
Post by nzlux »
MihiT wrote:Unless there's a known solution for the vehicle, my general advice would be to pull the cluster and re-solder all the connections on the daughterboard. Check for wires around the steering column that are pulling, pinching or rubbing.
That is how if fixed faulty tachs in my pajero and hilux
Return to “Isuzu”
