injectors for xj cherokee
spanky
Post by spanky »
just fitted a set of ba xr6 injectors into the old girl,definitely an improvement for throttle response, maybe a little gain in power but the main gain is alot crisper throttle , gone from the old style single hole injector to the new style 4 hole.will allow for a lot more fuel once a bit of boost is added,same injectors for both the na xr6 and the turbo, only difference is na runs 2.7bar fuel pressure and turbo runs 4.0bar, straight fit in too.
TJ
Re: injectors for xj cherokee
Post by TJ »
Wouldn't that make them compatible with TJ 4.0l engine as well?
Crash bandicoot
Post by Crash bandicoot »
Did similar to the pajero using multipoint injectors from later model diamante
Ant
Post by Ant »
Awesome info. Will have to remember this one.
Did you use the NA ones or the turbo ones?
92 LWB Safari TD42
spanky
Post by spanky »
TJ, i think they would fit any of the post renix motors?. Ant ,the turbo and the non turbo xr6 use the same injectors, non turbo runs 2.7bar fuel pressure and the turbo runs 4.0bar ,they are a 100% straight swap , main advantage on a std motor is that they are the new style 4 hole instead of one, would be interesting to see how they go on a road legal jeep to see if you get any improvement in milage
Return to “Jeep”
