Sump leak g16b
Posted: Mon Nov 21, 2016 12:53 pm
by massivenuts
Has anyone changed the oil sump gasket on a g16b without pulling the engine? Looks it should come out by dropping the diff out the way?
Re: Sump leak g16b
Posted: Mon Nov 28, 2016 6:22 pm
by deadduck
Yes I have now done it twice drop the diff then undo all the sump bolts turn steering one way to get drag link out the way and fight and move in a way where you can get it around the drag link.
Re: Sump leak g16b
Posted: Fri Dec 02, 2016 8:56 am
by massivenuts
deadduck wrote:Yes I have now done it twice drop the diff then undo all the sump bolts turn steering one way to get drag link out the way and fight and move in a way where you can get it around the drag link.
Did you drop the pick up at the same time? I have it off but it looks like it's gonna be an ass to get back around the pickup and in without disturbing the RTV bead?
Re: Sump leak g16b
Posted: Sun Dec 04, 2016 10:31 pm
by deadduck
No I had it all on the pick up isnt the problem its the drag link that takes some rtv i got sick of rtv so i put a cork gasket
Re: Sump leak g16b
Posted: Mon Dec 05, 2016 9:14 am
by massivenuts
deadduck wrote:No I had it all on the pick up isnt the problem its the drag link that takes some rtv i got sick of rtv so i put a cork gasket
I got it in there and it hasn't leaked overnight. every other person online has said the cork gaskets are shit, has it sorted your leak?
Re: Sump leak g16b
Posted: Mon Dec 05, 2016 6:45 pm
by deadduck
I had to put a new sump on my engine hit the front diff but it hasent leaked since using the cork gasket
