Are the Jeep Cherokee diffs (Dana 30 etc) able to be run with the front hubs locked constantly ie so the vehicle can be run in constant 4x4 at all times.
Cheers.
Jeep Cherokee diffs.
Re: Jeep Cherokee diffs.
Think the earlier ones run a system similar to the pajero where one axle is disengaged and the transfer disengages but one wheel still spins the spider gears in the diff when in 2wd.
So first need to determine what year axles ya looking at .
Depends on the transfer case, some had full time, most XJs in nz probably don't. IIRC the V8 ZJ had a full time xfer case (NP23xx) ??nivaman wrote:Are the Jeep Cherokee diffs (Dana 30 etc) able to be run with the front hubs locked constantly ie so the vehicle can be run in constant 4x4 at all times.
Cheers.
Yeah fixed drive flanges, kind of a bummer.
I dunno. Full time 4wd - either you're into it or you're not.
Cheers.
Seems I may have to see what transfer case the Cherokee has to determine if the diff has hubs or not?.
Wont have free running hubs from the factory irrespective of whether its full time or part time.
And free running hub conversion for a Dana 30 is around $1500USD cause of the unit bearing setup
Yeah the transfer case should have a tag on it somewhere with model number, would be a good start
What length are the Cherokee diffs hub to hub.
Looking for width of diffs, not width of vehicles.yeti wrote:https://en.wikipedia.org/wiki/Jeep_Cherokee
nivaman wrote:Looking for width of diffs, not width of vehicles.yeti wrote:https://en.wikipedia.org/wiki/Jeep_Cherokee
yeah na that's all in there as well.....no no don't thank me ..................
v8 tj...luvs the gas......
Didn't see it in there sorry.
