Jeep Cherokee diffs.
Posted: Thu Dec 01, 2016 11:28 am
by nivaman
Are the Jeep Cherokee diffs (Dana 30 etc) able to be run with the front hubs locked constantly ie so the vehicle can be run in constant 4x4 at all times.
Cheers.
Re: Jeep Cherokee diffs.
Posted: Thu Dec 01, 2016 11:40 am
by Crash bandicoot
Think the earlier ones run a system similar to the pajero where one axle is disengaged and the transfer disengages but one wheel still spins the spider gears in the diff when in 2wd.
So first need to determine what year axles ya looking at .
Posted: Thu Dec 01, 2016 11:42 am
by Crash bandicoot
duh moment. So yeah the earlier hubs were just spline plates locking the hub to the axle so yes they are engaged all the time.
Posted: Fri Dec 02, 2016 2:27 am
by lax2wlg
nivaman wrote:Are the Jeep Cherokee diffs (Dana 30 etc) able to be run with the front hubs locked constantly ie so the vehicle can be run in constant 4x4 at all times.
Cheers.
Depends on the transfer case, some had full time, most XJs in nz probably don't. IIRC the V8 ZJ had a full time xfer case (NP23xx) ??
Yeah fixed drive flanges, kind of a bummer.
I dunno. Full time 4wd - either you're into it or you're not.
Posted: Tue Dec 06, 2016 7:25 pm
by nivaman
Cheers.
Seems I may have to see what transfer case the Cherokee has to determine if the diff has hubs or not?.
Posted: Tue Dec 06, 2016 7:54 pm
by lax2wlg
Wont have free running hubs from the factory irrespective of whether its full time or part time.
And free running hub conversion for a Dana 30 is around $1500USD cause of the unit bearing setup
Yeah the transfer case should have a tag on it somewhere with model number, would be a good start
Posted: Sat Dec 17, 2016 10:20 am
by nivaman
What length are the Cherokee diffs hub to hub.
Posted: Sat Dec 17, 2016 5:30 pm
by yeti
Posted: Sun Dec 18, 2016 2:32 pm
by nivaman
yeti wrote:https://en.wikipedia.org/wiki/Jeep_Cherokee
Looking for width of diffs, not width of vehicles.
Posted: Sun Dec 18, 2016 3:00 pm
by yeti
nivaman wrote:yeti wrote:https://en.wikipedia.org/wiki/Jeep_Cherokee
yeah na that's all in there as well.....no no don't thank me ..................
Posted: Mon Dec 26, 2016 1:18 pm
by nivaman
Didn't see it in there sorry.
