Toyota drop pitman arm.
Does anyone know who does a replacement pitman arm for the Toyota IFS steering boxes to go away with the ball joint at the end so can just use a normal tie rod end instead? Or if any one has one they don't need.
Re: Toyota drop pitman arm.
Dunno if this helps or not,
I'm running a hilux/surf IFS box with a dropped pitman arm that has the tapered hole in it for a cruiser drag link, however I'm not too sure what the pitman arm is off. I'm guessing it's a KZJ/LJ 71/78. Anyway, the spline size/count matches the IFS box.
So they are out there, maybe look around a few wreckers just to get an idea.
Toyhatsu Bitsalux
