SJ 413 new wheels
Posted: Wed Feb 08, 2017 12:42 pm
by Santas60
hey guys.
i have a SJ 413 and want to fit larger tyres, however i am pretty certain i need more offset as the tyre is most likely going to hit the leaf when at hard lock.
So im wondering if there are any wheels that are fitted as OEM to other vehicles that will fit the SJ stud pattern, but also give me the offset i need to run a 31 inch tyre. i am after a 15 inch rim.
i also should add this is a very budget build, hence the question!
cheers guys. :D
Re: SJ 413 new wheels
Posted: Wed Feb 08, 2017 5:35 pm
by Crawlerer79
I have some steelies for a Zook that I'll sell ya. Bought them for my Escudo but won't be running them after all. Mega offset. Centers have been flipped by Zukmeista.
As for what you really need, I'm not 100%, someone else should be able to tell you...
Posted: Wed Feb 08, 2017 8:16 pm
by Santas60
Hey man, thanks for the offer, appreciate it.
however i want to get the zuk road legal..... not sure if flipped rims are legal?
Posted: Thu Feb 09, 2017 3:43 pm
by Crawlerer79
Legal? Well ummm....
Posted: Fri Feb 10, 2017 7:48 am
by Santas60
huh??
:lol:
Posted: Fri Feb 10, 2017 3:56 pm
by Swamped
I ran cj jeep rims on mine for a bit. 15x8 though so a bit wide.
Do be careful as rims with the correct offset for a samurai can scrub the springs like you are worried about because the 413 diff is slightly narrower. You can set up steering limit bolts to fix it but you increase your turning radius.
Posted: Fri Feb 10, 2017 9:11 pm
by zukmeista
Santas60 wrote:Hey man, thanks for the offer, appreciate it.
Technically probably not but most wof inspectors wouldn't notice
Posted: Fri Feb 10, 2017 9:54 pm
by derk
its perfectly legal to flip centres the same as widening rims, changing centres and beadlocking but it has to meet lvvta criteria and pass their certification to be used on a road vehicle
Posted: Fri Feb 10, 2017 10:37 pm
by Santas60
derk wrote:its perfectly legal to flip centres the same as widening rims, changing centres and beadlocking but it has to meet lvvta criteria and pass their certification to be used on a road vehicle
ok, thats intersting, didnt know that. :mrgreen:
Posted: Sat Feb 11, 2017 10:49 am
by Santas60
Swamped wrote:I ran cj jeep rims on mine for a bit. 15x8 though so a bit wide.
thats interesting.
was the offset ok?
Posted: Sat Feb 11, 2017 8:11 pm
by Swamped
Yeah more room than I needed. Too much offset and larger tyres will hit the firewall even with 31's. 31's will sap more power than you expect too
Posted: Sun Feb 12, 2017 2:06 pm
by Santas60
Swamped wrote:Yeah more room than I needed. Too much offset and larger tyres will hit the firewall even with 31's. 31's will sap more power than you expect too
ok, would you recommend about a -20mm offset or that a bit much?
Posted: Sun Feb 12, 2017 9:53 pm
by Swamped
Depends on your rim width and tyre combo what offset suits. Is the truck on the road? need to keep the tyres in the guards?
From memory, the 15x8 -19 stuck the tyre just too far out the guard for a wof. Would suit the samurai I expect.
Posted: Mon Feb 13, 2017 5:55 am
by Santas60
Swamped wrote:Depends on your rim width and tyre combo what offset suits. Is the truck on the road? need to keep the tyres in the guards?
well its got a set of 27s on atm..... but want to get 31 by 10.5s on there in the future
nah its not on the road currently, but working on it to bring it up to legal spec so it can be, however.
yeah well i am expecting to have to make flares for it, so thats alright.
but there werent any other issues to speak of when running that king of offset though?
