Turbo kit is from a QD32 engine I just bought.
I have absolutely no idea what it's worth so if it is too cheap or too expensive somebody please tell me !
$400 plus shipping. Located in Wellington but can ship at buyers expense
I have not had this engine running so I have not tested it but I believe it to be in good working condition. I saw somebody put a link up to the engine on trademe recently and I believe they are a friend of the previous owner so if they read this thry could confirm
The kit includes :
-Schwitzer turbo - journal bearing - oil cooled only. I am no turbo expert, it has a small amount of play, it requires a wee bit of force to feel the play. It doesn't appear to have made contact with the housing.
-7.5 PSI waste gate actuator
-Turbo outlet to 3" V band adaptor.
- dump pipe (2.5" outlet I think )
- oil feed line and return. ( might need a longer rubber tube if installed on a TD )
- QD32 turbo exhaust manifold, looks to flow a hell of a lot better than the TD27T ones
I'll add photos when I figure out how to
FS QD32 / TD27 Turbo kit
Re: FS QD32 / TD27 Turbo kit
Got a 32 intake you can part with?
Long runner 2 piece style.
