Mainland WC rule book
Hello chaps,
link to 2017 rule book for those interested
Any Q's about it just ask here please
Re: Mainland WC rule book
Sorry guys but a few little things have been picked up on and will be corrected.. hopefully in the next week.. I have removed the link from my google drive until the new pdf is available..
more later
more later
- Crawlerer79
Looking forwards to it.....
'Lando' - 1994 V8 Disco
Thank you for the time and effort, it is appreciated
- Crawlerer79
Can you tell us what the outcome was with the cage for clubman debate? Thanks
census is for a minimum of a single roll bar behind driver and co driver.. due to a club truck having a roll over last year and having collapsed the roof a wee bit.. But this is still being decided.. I'll know in due coarse..Crawlerer79 wrote:Can you tell us what the outcome was with the cage for clubman debate? Thanks
- Crawlerer79
Sweet thanks.... any idea how far behind the front seats the bar can go back?
you might have to wait for details sorry.. but i would think it would be inline with the oranz rules or there aboutsCrawlerer79 wrote:Sweet thanks.... any idea how far behind the front seats the bar can go back?
- Crawlerer79
Right thanks
- Crawlerer79
Any idea on how much longer until the rulebook will be re-released? Thanks
Crawlerer79 wrote:Any idea on how much longer until the rulebook will be re-released? Thanks
Hey mate we are just going through the final bits to get it ready.
email me mainlandwinching@gmail.com and I will send it out once it has all been amended. This is the correct way to get the latest rule book available. Any online versions my be out of date.
Cheers Leigh
- Crawlerer79
Thanks for that, have emailed you. Cheersimsohi wrote:Hey mate we are just going through the final bits to get it ready.
Cheers Leigh
hi there, could you post up information reguarding the different classes and requirement for each class, specifically roll cage requirements?
thanks, Tim.
thanks, Tim.
Clubman class is debating the type of roll cage atmTimmy511 wrote:hi there, could you post up information reguarding the different classes and requirement for each class, specifically roll cage requirements?
thanks, Tim.
Outlaw = min 6 point cage
Open = min 6 point roll cage
rules shouldnt be too much longer
when you read the rule book, please keep in mind that the clubman roll bar is still being discussed.. but apart from that it should be good..
- Crawlerer79
Sweet thanks, so has the 50 point per mod rule gone or something? Didn't see it there. Also doesn't specify Clubman A and B tyre sizes... just 930mm for clubman. Does that mean A and B have been merged? CheersBig wrote:when you read the rule book, please keep in mind that the clubman roll bar is still being discussed.. but apart from that it should be good..
basiclly yea.. 35" max tyre size for clubman..not sure on the mod points system.. will ask..Crawlerer79 wrote:Sweet thanks, so has the 50 point per mod rule gone or something? Didn't see it there. Also doesn't specify Clubman A and B tyre sizes... just 930mm for clubman. Does that mean A and B have been merged? CheersBig wrote:when you read the rule book, please keep in mind that the clubman roll bar is still being discussed.. but apart from that it should be good..
- Crawlerer79
So Clubman A and B are gone? What are guys in the little Zooks gonna do? They can't really go stuffing 35's on.... not really gonna make for such an even playing field...Big wrote:basiclly yea.. 35" max tyre size for clubman..not sure on the mod points system.. will ask..Crawlerer79 wrote:Sweet thanks, so has the 50 point per mod rule gone or something? Didn't see it there. Also doesn't specify Clubman A and B tyre sizes... just 930mm for clubman. Does that mean A and B have been merged? CheersBig wrote:when you read the rule book, please keep in mind that the clubman roll bar is still being discussed.. but apart from that it should be good..
It was interesting to look at the Clubman truck line-up at the Timaru winch challenge during scrutineering...
Differences in diff clearances were VERY obvious (largest to least)
Zooks on 33's
Hilux on 35's
Zook on 32's
Hilux / Jeep on 33's
Landrover on 35's (Nissan axles/diffs)
Cruiser on 33's
Tyre size alone is not a significant factor in comparing trucks...
Then there was a range of diff configurations - some open, some LSD to double lockers
And winches super slow Supercheap, to PTO to double motor 2-UP and enlarged drums...
Just saying it never was an even playing field - but it's a class intended for lower-spec trucks and less experienced drivers where there is less likelihood of rollovers or serious damage and therefore less expense and modification needed. My goal was always to finish every stage (which never happened), and 2nd goal was setting a good time... Which happened occasionally...
Zooks on 33's
Hilux on 35's
Zook on 32's
Cruiser on 33's
tyre size is not an issue, the suzuki will out perform any truck out the if its set up well and the driver thinks about what he is doing.
had as much fun in my zuk as i did in my winch truck.
even preferred the zuk in some events.
- Crawlerer79
Right ok guys fair enough.... thanks for that. Will be interesting to see if the 50 point mod list is still around....
Hey mate not sure what you mean by the 50 point mod. I have never heard of it in the years I have been competitingCrawlerer79 wrote:Right ok guys fair enough.... thanks for that. Will be interesting to see if the 50 point mod list is still around....
- Crawlerer79
Page 7 of http://www.4x4challenges.org.nz/downloads/131imsohi wrote:Hey mate not sure what you mean by the 50 point mod. I have never heard of it in the years I have been competitingCrawlerer79 wrote:Right ok guys fair enough.... thanks for that. Will be interesting to see if the 50 point mod list is still around....
Now that I look at it I'm wondering if that just applies to the North Island competition....
