2017 Hilux, What does the power button do?
gary_in_nz
Post by gary_in_nz »
Work must making some money as they have scored a couple new hilux's. Was wondering what the power button next to the gear stick does? Is that a bit of over boost function or something?
sirLachlan
Re: 2017 Hilux, What does the power button do?
Post by sirLachlan »
Ha ha good luck .
All it does is change the shift points in the auto .
If your driving it like s lunatic round some corners it will make it rev out more before shifting and kick down earlier
gary_in_nz
sirLachlan wrote:Ha ha good luck .
these are manual wagons 2wdI, I know what you are saying, i got an 80 series auto with the same thing but the manual luxys have this function also.
johnny262
Post by johnny262 »
Dunno what the button officially does, but in real world driving it turns them into absolute mutts to drive lol. The gentler you are on the accelerator the faster they rev... stick your foot flat and they bog down like your in too higher gear.
Traction control system has a nervous breakdown every time you turn a corner on gravel, can't imagine them being much good for work/farm
I think Mr Toymota maybe missed the mark this time round
Bring back Barry :mrgreen:
mudsurfv6
Post by mudsurfv6 »
Andrew 0272226292.
gary_in_nz
Had a quick play at work this evening, held foot at 1500rpm in second, pressed power, truck accelerates to 4000rpm without any depressing of the accelerator. Seems its set up for aggressive driving with better throttle response being a fly by wire.
Actually quite impressed with the spec level of the gear included in the base model.
