2000 hilux ifs axle seal
Posted: Tue Apr 25, 2017 8:01 pm
by d_b
Hi, passenger side front diff axle seal looks to be leaking 2000 hilux, have removed cv etc unbolted it from flange, need to remove the axle assembley (circled in blue)... i see from this schematic there is a snap ring, does this need to be removed from inside the diff? ie unbolt the front diff cover to remove? (misson) or through the 4wd actuator housing or big slide hammer?
The seal i think i need to replace is circled in red.
Any help appreciated
daniel
Re: 2000 hilux ifs axle seal
Posted: Wed Apr 26, 2017 8:24 pm
by d_b
So yeah.. drop diff oil. Remove 4wd actuator, remove snap ring and you're good to go..
Posted: Fri Apr 28, 2017 8:44 pm
by slide
remove whole side assembly from diff, don"t try to remove axle from inside tube
