Thought I may as well start a build thread
After my last single cab hilux got pinched i bought a cheap Pajero and a pos lwb safari then about a year ago I found another single cab ln106 with a 5l turbo motor in it
First thing to go on it was a set of 33x10.5 bfg km2
Then a 50mm bodylift to stop the guard rubbing
During the bodylift install I found some rust around the body mounts which is still yet to be fixed
Aim for this build is
RUF with highsteer in the front
Sheep shagger springs in the back
Winchbar / winch
Recovery points front and rear
Custom flatdeck with decent rollover protection
4.5 diffs with lokka in the rear will stay open in the front for now
A.c pump onboard air with outlets on the front and back of truck
Eventually want be able to run in clubman class winch challenges as well as being able to use it for hunting trips in the backcountry
Will get some photos up in the next few days
Alex
5l turbo hilux
Re: 5l turbo hilux
sounds good, make sure you keep the photos coming as it changes.
Andrew 0272226292.
Andrew 0272226292.
Re: 5l turbo hilux
High steer kit and extended shackles are on there way
Drop crossmember is almost done
And bar is all bolted up
Might add a few gussets here and there to keep it nice and strong and then a clean up and lick of paint
Re: 5l turbo hilux
Anyone know where i can get the ifs hub spacers in nz or do I have to order from the state's?
