KZN185 bits
rangimotors
KZN185 bits
Post by rangimotors »
Hi all,
Is anyone making replacement panhard brackets for a KZN185 after a lift or have pictures of one they have knocked up?
Same question with dump pipes for the 1kz-te, it looks like a pain in the ass..
Also as of interest has anyone needed replacement extended brake lines after a 2 inch lift? The fronts dont flex and the back "extended" shocks are not that long so I cant see it but any advice would be appreciated. Ill twist it up as much as i can but if I definitely need them it would be good to get them ordered
Dave
BlakeNZ
Re: KZN185 bits
Post by BlakeNZ »
with only a two inch lift, i'm not sure you need to do the panhard bracket drop. the angle doesn't change that much. I had a 3" drop bracket , and despite a decent lift, my wheel alignment guy said there was no need for the drop bracket to be fitted yet.
rangimotors
Re: KZN185 bits
BlakeNZ wrote:with only a two inch lift, i'm not sure you need to do the panhard bracket drop. the angle doesn't change that much. I had a 3" drop bracket , and despite a decent lift, my wheel alignment guy said there was no need for the drop bracket to be fitted yet.
Great to know thanks
