wd 21 rear springs
For all Nissan related topics
scratcher
wd 21 rear springs
Post by scratcher »
like to get the rear back to original or slightly higher for towing. Used some chamberlin springs last time but the ride wasnt cmfortable for touring . 50mm lift would work but retain its good manners
BlakeNZ
Re: wd 21 rear springs
Post by BlakeNZ »
cheap option would be spring spacers. also most closely matches factory ride. You would need a 25mm spacer to gain 50mm ride height. Don't ask me why or what the logic is behind that. It just happens.
and BTW congratulations on your 5th post in 13 years on this forum ! :) I'm guessing you are the strong silent type.
